TractorLinks.com
Show Parts for Model:
Re: OT toyota sienna bearing
Jim WI
12-28-2012 10:08:07
Google is your friend...
http://www.fixya.com/cars/t13583653-toyota_sienna_wheel_bearing
http://www.siennachat.com/forum/64-2004-2010-dec-2009-2nd-generation-toyota-sienna/9274-2005-front-wheel-bearings.html
It sounds like the best thing to do is take the hub assembly to a part store and have them do the pressing in and out.
Britcheflee
12-28-2012 10:31:46
 Re: OT toyota sienna bearing in reply to Jim WI, 12-28-2012 10:08:07
Thanks,
i think that is what I am going to do - I was able to get some good information about removing it - which I think I am going to be able to do - the removal and replacement of the hub and bearing I am going to leave to someone else mainly because I dont have the correct tools for the job - I was quoted about $500 for bearing hub replacement and I am sure a large proportion of this was the labor which I can do.
Of course the weather is against me - this is when I really wish I had a nice dry garage to do the work in - crawling around on wet dirt in the freezing cold is not my idea of fun.
The sienna is still chugging along - it is using up a lot of oil, has a leaky valve cover, and the check engine light is constantly on due to cat not working right - but so far has not died on us.
lee
old
12-28-2012 11:39:43
 Re: OT toyota sienna bearing in reply to Britcheflee, 12-28-2012 10:31:46
When working out side card board is your friend. Find a far sized box open both ends and lay it on the ground then use that to sit kneel what ever on and you will be a whole lot warmer BTDT way way to many times. Same if you have to go under a car or truck a box like with a washer or dryer comes in works great to lay on
