wagner wm4 loader on my 2n
fitter8
New User
hey guys ,just looking for a manual for the loader redoing my 2nand just picked up the loader but one of the sliders on the hydraulic control is broke where it connects to the handle looking for a manual and parts list so i can fix this , also need advice if this is going to hook up to the front of the 2n ,whats needed ,could use the help ,thanks fitter8 :roll: :lol:
(quoted from post at 17:03:20 12/27/12) hey guys ,just looking for a manual for the loader redoing my 2nand just picked up the loader but one of the sliders on the hydraulic control is broke where it connects to the handle looking for a manual and parts list so i can fix this , also need advice if this is going to hook up to the front of the 2n ,whats needed ,could use the help ,thanks fitter8 :roll: :lol:
I can send you a copy of the loader manual. If the part that is broken is one of the control valve spools you will likely find it cheaper and easier to simply replace the entire valve.
The loader will mount to your 2N if it has the late 8N style axle support but you will need the front hanger and pump mounting bracket. Did you get one with the loader? If not I can provide one that will work with either the late or early style axle support. Click the image thumb for a full size image.
TOH
Most of the "wonder-trol" control valve models are shown near the
back of the manual at
http://www.wagnercompanies.com/domains/wagnercompanies/files/pdf/wagner_loader_owners_manual.pdf
sure would be thankful if you could send me a copy of the manual. i have a bracket on the front with three holes across i guess this is for mounting to the front of the tractor.thanks rick
