TractorLinks.com
Order Ford 8N Parts Online
Re: 12 volt conversion on 1947 8n
JMOR
12-28-2012 07:02:48
Quoting Removed, click Modern View to seeSure does sound like you are missing the ammeter or do not have ammeter wired correctly
Trc8000
12-29-2012 06:05:40
 Re: 12 volt conversion on 1947 8n in reply to JMOR, 12-28-2012 07:02:48
Before the starter locked up and I replaced with new starter and solenoid, all of the wiring was correct from ammeter, ignition, push button, and starter. I swapped everything out and wasn"t sure about the wire from key ignition switch going to right side of solenoid cause all the diagrams didn"t show it that way. Dell confirmed that it was ok to run that way. So it looks like everything is back where it was before starter crapped out. I"m hopping the reason I"m only getting a "click" is due to bad battery, but I"m afraid it may be a bad new solenoid. Heading to get battery checked now. I"ll keep you posted. Thanks for your help and patience.
JMOR
12-29-2012 06:20:54
 Re: 12 volt conversion on 1947 8n in reply to Trc8000, 12-29-2012 06:05:40
"OK" is sort of 'OK', I guess, but I don't see your ammeter telling you much, as it will not read either charging or discharging (load) current as wired, with alternator & ign both tied directly to battery side of solenoid.......but the tractor should run like that.
"Click" is most often a bad connection at one end of either battery cable, a weak battery, a bad cable, a bad starter with a good solenoid. If with a known good battery, you still have same results, after ensuring connections & cables, give starter housing a good solid 'whack' while holding the start button down. Sometimes this will temporarily gain brush to commutator contact when brushes/brush springs are shot.
