| Author |
[Modern View]
| wrenchtech
12-27-2012 18:57:19
173.54.19.149
Does anyone know were to get a pulley for it? or know of a good replacement? |
[Reply] [No Email] | |
| Kurt-NEPA
12-29-2012 06:23:45
70.44.245.96
Re: dearborn front plow in reply to wrenchtech, 12-27-2012 18:57:19
| Wow UD, You flatter me. The tractor is much better than I am! |
| Kurt-NEPA
12-29-2012 03:42:04
70.44.245.96
Hey UD - I know that old bald head. Thats me on my 8N with an ARPS frame and Dearborn plow. Taken about 2 years ago.
Here is another pic.
Kurt |
| Ultradog MN
12-29-2012 05:50:37
184.100.109.75
Re: dearborn front plow in reply to Kurt-NEPA, 12-29-2012 03:42:04
| Ah ha, I wondered who that man was with the glabrous pate and wizened mien :) Great photos Kurt. Nice rig for moving snow too. |
| Bob Harvey
12-28-2012 18:02:35
209.121.225.193
| I think what you are looking for is called a 'sheave'(sp). Measure what you have and take the information to your local hardware, store, or go online. As Stan provided (heybusdriver), they are readily available. I looked them up in the 'Princess Auto' cataqlogue about 2 yrs.ago for the same reason. P.S., Princess Auto =your local bulk (mainly Chinese made) outlet. HTH |
| wrenchtech
12-28-2012 19:03:45
173.54.19.149
Re: dearborn front plow in reply to Bob Harvey, 12-28-2012 18:02:35
| I checked out princess autos web site. they look great. which ones did you use, the orange 4in. ones or the silver 3-1/2in. ones? doesn't tell me the pin size. he orange ones look perfect though. doug |
| Bob Harvey
12-28-2012 19:32:18
209.121.225.193
Re: dearborn front plow in reply to wrenchtech, 12-28-2012 19:03:45
| Doug, what I was doing fell through, the thing of it is = the 'pulley/sheave' is readily available. Have Phun !! & Happy NY! |
| heybusdriver
12-28-2012 19:28:40
70.71.96.170
| | I think I purchased the 4 inch pulleys, I don't have it here so can't measure for sure. I forget what I paid but good nice pulleys. Stan 9N 222933 2N with 8N motor 8N345567 8N 146710 8N 179555 8N 197904 8N 199000 8N 254079 8N 362039 |
| 8N'r--WI
12-28-2012 12:23:12
75.9.168.167
| | wrenchtech----if you must have original, I have a NOS pulley for your Dearborn Front Plow... Let me know..... Tim |
| wrenchtech
12-28-2012 18:38:08
173.54.19.149
Re: dearborn front plow in reply to 8N'r--WI, 12-28-2012 12:23:12
| Well, it maybe my only choice. How much do you want for it? doug |
| 8Nr--WI
12-28-2012 12:35:38
75.9.168.167
|  Frame for the Dearborn |
| jubileepa
12-28-2012 16:25:26
74.47.48.85
Re: dearborn front plow in reply to 8Nr--WI, 12-28-2012 12:35:38
| hi new to this forum, awsome picture, I bought a dearborn snw plow this summer. I have a 1954 nna and of course those back brakets were no where in sight, thankfully I knew enough to spot the front ones though. so any help to make or find plans for them would be great thanks. :D |
| wrenchtech
12-29-2012 14:53:18
173.54.19.149
Re: dearborn front plow in reply to jubileepa, 12-28-2012 16:25:26
|  J, here is a quick drawing of the left rear mount with dimensions. hope this helps. doug |
| 8N'r--WI
12-28-2012 18:50:49
75.9.168.167
| | If you know where to find the "other site" , they have a complete manual for the Dearborn Dozer/Snow Blade that you can copy. On the same site, in the "How To's" Section, someone has posted closeup pics and diagrams with dimensions for making your own rear brackets for the Dearborn. There are some real handy guys on both sites that may be able to fab some of the brackets for you. If you start a new post on both sites, just ask if someone would be able/willing to build them, or try it yourself. I had a complete all original Dearborn Snow Plow that I just sold this summer after upgrading my 860 to do snow plowing. Over the years, I acquired some NOS pieces for it, cables, pulleys, etc. Hard to find as a lot of times the brackets end up being sold with the tractor instead of being taken off with the implement. Note: Although there were some original frames built for the Jube and 100 Series Tractors, most of the frames were built for the N Series Tractors.....the Jubes and 100 Series are about 4" longer than the N's, so if your plow is too "short", you can just cut the frame, slip in another shorter piece of pipe and weld up so it works on your Jube. Good Luck.....those plows can move a lot of snow with the right weight systems. Tim |
| jubileepa
12-29-2012 14:13:04
74.47.48.85
Re: dearborn front plow in reply to 8N'r--WI, 12-28-2012 18:50:49
| tim I think your right about the lenth but maybe we can make up the extra lenth in the brakets i need to fab thanks for pointing that out to me. jubileepa |
| wrenchtech
12-28-2012 18:42:47
173.54.19.149
| I've got my set in the garage. I'll get one out and see if I can make some drawings for you. doug |
| Mr. T. Minnesota
12-28-2012 16:58:54
68.170.114.158
| J, What exactly are you looking for? In my post on this subject I utilized part of the front end plow on an R2 Cat in northern Minnesota. I may have the back assembly (part that hooks to the hydraulic arms). I am not going to use it except for scrap steel. Mr. T. Minnesota |
| jubileepa
12-29-2012 14:08:48
74.47.48.85
Re: dearborn front plow in reply to Mr. T. Minnesota, 12-28-2012 16:58:54
| Quoting Removed, click Modern View to see Thanks for the replys the parts i need are numbers 20,21,29, in the plow manual photo thanks mr T |
| wrenchtech
12-28-2012 18:35:42
173.54.19.149
| I need one of the pulleys/sheaves that are mounted on the frame towards the front.Do you have one on the remaining part of the frame? |
| 8Nr--WI
12-28-2012 19:02:20
75.9.168.167
Re: dearborn front plow in reply to wrenchtech, 12-28-2012 18:35:42
| | Doug, Where are you located? If you pick it up, you can have it. Otherwise $15 including the shipping (probably costs $10 for USPS?) My stompin grounds are from Milwaukee to LaCrosse WI Tim |
| Ultradog MN
12-29-2012 05:55:12
184.100.109.75
Re: dearborn front plow in reply to 8Nr--WI, 12-28-2012 19:02:20
| Hey Tim, You should have made him promise to say a few Rosaries too so you finally get a buck.
| wrenchtech
12-28-2012 19:09:33
173.54.19.149
| that sounds good. I'm in jersey so shipping is best. how do you what payment? |
| 8Nr--WI
12-28-2012 19:15:13
75.9.168.167
Re: dearborn front plow in reply to wrenchtech, 12-28-2012 19:09:33
| | Doug, I will dig it out of the garage and send you a pic of it tomorrow via email with additional info..... Tim |
| wrenchtech
12-28-2012 19:24:08
173.54.19.149
Re: dearborn front plow in reply to 8Nr--WI, 12-28-2012 19:15:13
| that's great tim.thanks doug |
| DrLarryE
12-28-2012 03:31:43
68.60.77.15
| What is a front plow? Sounds like a plow for the front of a tractor, but I"ve never heard of anything like that (of course I live a sheltered life!) |
| Ultradog MN
12-28-2012 14:24:55
184.100.109.75
Re: dearborn front plow in reply to DrLarryE, 12-28-2012 03:31:43
| | I don't know who this is. I just did a search and it was on photobucket. So thanks to whoever put it up on PB. It is a nice photo.
| russb wa
12-28-2012 10:39:08
67.185.6.72
| LOL, I knew it was a blade, but somehow, got the idea it was lashed to a loader frame. |
| Mr. T. Minnesota
12-28-2012 04:09:08
68.170.114.158
| Larry, Believe the front plow they are talking about is one that was lifted with a series of two cables and pulleys lifting from the rear lift arms of the N tractor. The main frame of the plow was under the N tractor. The blade pivoted which was nice. Had one that I converted into a plow for an R2 Cat. On occasion you may see one in the photo ad section of this site.Hope this helps!! Mr. T. Minnesota |
| heybusdriver
12-27-2012 21:32:37
70.71.96.170
| | How many do you need? 1 or 2? When I got my plow 1 of the pulleys was missing, I attempted to make a 2nd one , I didn't complete it because I found a nice pair at Princess Auto. The one came with my plow I don't know if it is original or not , the one I made only needs to be drilled and a bushing put in the hole. I can't seem to post pictures here any more but will send a email with photos. Stan 9N 222933 2N with 8N motor 8N345567 8N 146710 8N 179555 8N 197904 8N 199000 8N 254079 8N 362039 |
| Den N Ms
12-27-2012 19:42:18
184.41.137.166
| wrenchtech, You might try here at Motion Control Technologies, Inc. |
| wrenchtech
12-27-2012 19:53:50
173.54.19.149
Re: dearborn front plow in reply to Den N Ms, 12-27-2012 19:42:18
| that might work. I'll have give them a call. |
| Den N Ms
12-27-2012 20:02:14
184.41.137.166
Re: dearborn front plow in reply to wrenchtech, 12-27-2012 19:53:50
| Or Try Graingers They have hundreds to choose from. |
| Den N Ms
12-27-2012 20:09:01
184.41.137.166
Re: dearborn front plow in reply to Den N Ms, 12-27-2012 20:02:14
| OR Here at VER. |
| wrenchtech
12-28-2012 18:49:29
173.54.19.149
Re: dearborn front plow in reply to Den N Ms, 12-27-2012 20:09:01
| graingers and ver sell them in the blocks. doesn't tell what the pin size is. would hve to go though them all to see. thanks for the help though. |
| Ultradog MN
12-27-2012 19:40:56
184.100.109.75
| Hi wrenchtech, I wote a reply to you over on implement alley. |
| wrenchtech
12-27-2012 19:54:40
173.54.19.149
Re: dearborn front plow in reply to Ultradog MN, 12-27-2012 19:40:56
| got it. thanks. |
| russb wa
12-27-2012 19:31:51
67.185.6.72
| Not sure if this is what you want: |
| wrenchtech
12-27-2012 19:51:22
173.54.19.149
Re: dearborn front plow in reply to russb wa, 12-27-2012 19:31:51
| I don't think so. there for mounting on the crankshaft. the pulley I need mounts on the plow frame and a cable rides in it to raise and lower the plow. |
