Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 12 volt conversion on 1947 8n
[Return to Forum]
Trc8000
12-27-2012 06:35:15
76.202.2.108
I just had to replace the starter on my 1947 8n that had just recently been converted to 12 volt system. When I went to hook up the solenoid I noticed the one wire from the key ignition was hooked to right side of solenoid. Every diagram I have looked at shows both wires from the key ignition running to the regulator. It seemed to be working fine, but could this be why I'm now replacing starter? I understand there are multiple ways to hook up the solenoid, I just want to make sure this way is acceptable.
Thanks,
Tim
[Reply]   [No Email]
soundguy
12-27-2012 17:38:23
184.247.82.82
 Re: 12 volt conversion on 1947 8n in reply to Trc8000, 12-27-2012 06:35:15
post the diagram pic you saw where BOTH wires from the key switch went to the regulator...
[Reply]  [No Email]
Trc8000
12-27-2012 20:18:21
76.202.2.108
 Re: 12 volt conversion on 1947 8n in reply to soundguy, 12-27-2012 17:38:23
Resister block not regulator....my mistake
[Reply]  [No Email]
soundguy
12-28-2012 14:30:41
173.136.2.100
 Re: 12 volt conversion on 1947 8n in reply to Trc8000, 12-27-2012 20:18:21
ah-ha :)
[Reply]  [No Email]
Dell (WA)
12-27-2012 09:03:16
63.226.211.116
Tim.........one of the reasons to convert to 12V is the FASTER spinning of the 6V-starter motor on 12V for eazier starting of worn low compression engine. The 6V-starter motor does just fine on intermittent 12V starter duty. There is NO problem, connecting yer ignition ON switch to the right side of the 3-terminal starter solenoid as you described. Iff'n you connected to the left side of yer 3-terminal starter solenoid, yer engine would only run while pushing the BIG thumb starter button by the tranny shifter.
Remember, yer 30-0-30 ammeter was originally wired for positive (+) ground and will read BASSACKWARD with negative (-) ground that yer 12V-alternator demands. Iff'n still the original "loop" ammeter, just thread the ammeter wire thru the loop the OTHER direction, otherwize swap leads on back of 2-terminal ammeter. Surprizingly enuff, ammeter don't care, positive (+) ...or... negative (-) ground and even more amazing don't care iff'n 6V or 12V.
HOWSOMEVERS: both the original 6V-squarecan coil and the modern 12V-squarecan coil use the same "infamous ballast resistor".......NO ARGUE!!! ........Dell, a 12V advocate for the right reason, who knows 8-ways to convert to 12V and they all work the first time
[Reply]  [No Email]
Trc8000
12-27-2012 15:10:00
76.202.2.108
 Re: 12 volt conversion on 1947 8n in reply to Dell (WA), 12-27-2012 09:03:16
Thanks Dell......so on the right side of the solenoid I got the ignition wire, positive battery cable, and wire from regulator coming from alternator. Left side is hooked to starter and small post in back is hooked to the push start button. Now all I gotta do is charge the battery and I should be good to go....
Thanks again.
Tim
[Reply]  [No Email]
JMOR
12-27-2012 07:19:04
72.181.173.171
Quoting Removed, click Modern View to seeShould be from battery terminal side of solenoid to ammeter & from ammeter to terminal block 3rd terminal.
[Reply]  [No Email]
Trc8000
12-28-2012 06:29:41
76.202.2.108
 Re: 12 volt conversion on 1947 8n in reply to JMOR, 12-27-2012 07:19:04
Well. I got everything hooked up to the new solenoid and
starter, everything seemed to be correct when I connected the
battery. No sparks or engine trying to start before I hit the
button, but unfortunately when I did hit the button all I got was
a click. The battery is less than a month old, put it on a charger
and it doesn't seem to be taking a charge. I"ll drag it back to
Wally mart to day and exchange it for a new one. Does it
sound like I'm missing anything?
Thanks
[Reply]  [No Email]
JMOR
12-28-2012 07:02:48
66.87.75.196
 Re: 12 volt conversion on 1947 8n in reply to Trc8000, 12-28-2012 06:29:41
Quoting Removed, click Modern View to seeSure does sound like you are missing the ammeter or do not have ammeter wired correctly
[Reply]  [No Email]
Trc8000
12-29-2012 06:05:40
76.202.2.108
 Re: 12 volt conversion on 1947 8n in reply to JMOR, 12-28-2012 07:02:48
Before the starter locked up and I replaced with new starter
and solenoid, all of the wiring was correct from ammeter,
ignition, push button, and starter. I swapped everything out
and wasn"t sure about the wire from key ignition switch going
to right side of solenoid cause all the diagrams didn"t show it
that way. Dell confirmed that it was ok to run that way. So it
looks like everything is back where it was before starter
crapped out. I"m hopping the reason I"m only getting a "click" is
due to bad battery, but I"m afraid it may be a bad new
solenoid. Heading to get battery checked now. I"ll keep you
posted. Thanks for your help and patience.
[Reply]  [No Email]
JMOR
12-29-2012 06:20:54
72.181.173.171
 Re: 12 volt conversion on 1947 8n in reply to Trc8000, 12-29-2012 06:05:40
"OK" is sort of 'OK', I guess, but I don't see your ammeter telling you much, as it will not read either charging or discharging (load) current as wired, with alternator & ign both tied directly to battery side of solenoid.......but the tractor should run like that.
"Click" is most often a bad connection at one end of either battery cable, a weak battery, a bad cable, a bad starter with a good solenoid. If with a known good battery, you still have same results, after ensuring connections & cables, give starter housing a good solid 'whack' while holding the start button down. Sometimes this will temporarily gain brush to commutator contact when brushes/brush springs are shot.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
