Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 8N Parts Online
Re: 8N won't start
russb wa
12-26-2012 15:23:04
With the ignition off probe both ends of the last resistor and see if you can determine the resistance in Ohms.
Then you can try a resistor with less resistance. A good experiment might be to get a variable resistor aka potentiometer of enough capacity and try starting. Work down from higher to lesser resistance. More resistance = less or no spark, not enough resistance = release the magic smoke. They have magic smoke inside. If it gets away they quit working.
russb wa
12-26-2012 15:24:07
 Re: 8N won't start in reply to russb wa, 12-26-2012 15:23:04
Use your VOM Volt Ohm Meter, to probe both ends of the resistor.
