TractorLinks.com
Order Ford 8N Parts Online
Re: 8N won't start
JMOR
12-26-2012 13:34:34
Quoting Removed, click Modern View to seeNeed to know if 6v or 12v coil (about 1 Ohm primary on 6v and about 2 1/2 Ohm on 12v). When you say 3 volts on coil wire, if you mean on the HV coil terminal, then that is not real meaningful. If you mean on the screw on top of coil, then the conditions under which you measured it is essential information. How many Ohms is the extra resistor & is the other resistor the stock (12250) resistor?
