| Ford 9N, 2N & 8N Discussion Forum |
Topic: 8N won't start
[Return to Forum]
| Author |
[Modern View]
| Swede in IOWA
12-26-2012 13:07:24
207.32.60.213
Fella drug a 49 8N front mount over to me. Says can you make it start and run. He "converted " it to 12v neg ground, and installed some kind of electronic ignition.Gets weak spark at plugs . He has 2 resistors in series in the wire feeding the coil.Does not seem right to me but I am not familiar with these electronic ignition deals.Getting 3 + volts on coil wire at coil. Do these resistors need to be in the circuit? Thanks Swede |
| Swede in IOWA
12-27-2012 08:06:45
207.32.60.213
Re: 8N won't start in reply to Swede in IOWA, 12-26-2012 13:07:24
| Thanks for the help Guys. I will do some checking on resistance and post back. Swede |
| russb wa
12-26-2012 15:23:04
67.185.6.72
| | With the ignition off probe both ends of the last resistor and see if you can determine the resistance in Ohms. Then you can try a resistor with less resistance. A good experiment might be to get a variable resistor aka potentiometer of enough capacity and try starting. Work down from higher to lesser resistance. More resistance = less or no spark, not enough resistance = release the magic smoke. They have magic smoke inside. If it gets away they quit working. |
| russb wa
12-26-2012 15:24:07
67.185.6.72
Re: 8N won't start in reply to russb wa, 12-26-2012 15:23:04
| Use your VOM Volt Ohm Meter, to probe both ends of the resistor. |
| jackinok
12-26-2012 13:54:29
162.58.82.136
| If i were GUESSING i would bypass one of the resistors. but that would be a guess without knowing all the particulars like bruce says. I would ask the fellow if it ran after he installed the electronic ignition/when the problem started etc. I have a old ferguson fifty to rewire,for a neighbor .he converted it to a alternator and was running it, when a wire started smoking. instead of pulling the battery cable off he just yanked all the wires out.if he werent a friend of my son i wouldnt mess with it. |
| JMOR
12-26-2012 13:34:34
72.181.173.171
| Quoting Removed, click Modern View to seeNeed to know if 6v or 12v coil (about 1 Ohm primary on 6v and about 2 1/2 Ohm on 12v). When you say 3 volts on coil wire, if you mean on the HV coil terminal, then that is not real meaningful. If you mean on the screw on top of coil, then the conditions under which you measured it is essential information. How many Ohms is the extra resistor & is the other resistor the stock (12250) resistor? |
| Bruce (VA)
12-26-2012 13:11:33
24.125.80.178
| | " Do these resistors need to be in the circuit? " Probably not. But until you can tell us the model of the EI unit & the value of the resistors, the chances are very good that just bypassing the resistors will let the smoke out of the EI. Or, simply adopt the 'no guts, no glory' attitude & bypass the resistors. It will probably start & run fine. If it's still running fine 3 months from now, it clearly did not need the resistors. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
