| Ford 9N, 2N & 8N Discussion Forum |
Topic: ford 8n low compression
[Return to Forum]
| Author |
[Modern View]
| Greg Pinelli
12-26-2012 07:00:48
97.73.48.60
I have a 1952 Ford 8n with low compression. #2,3,&4 all had around 40psi, even after I replaced the rings, bearings, honed cylinders, lapped valves, etc. I am at a loss. Any suggestions? |
| Fuddy Duddy
12-26-2012 19:51:51
75.229.125.189
Re: ford 8n low compression in reply to Greg Pinelli, 12-26-2012 07:00:48
| I agree with Old. Did you use the old cylinders? If you did, did you mike them or check them in any way? I can't see going thru one of these engine and not putting in new cylinders. That's the great thing about these engines. New cylinders equal new engine. Need more information as to what all you did to the engine. |
| ASEguy
12-26-2012 16:26:46
68.186.162.134
| How was number one cylinder? I assume the throttle was blocked open with good airflow and you had sufficient cranking RPM? I'd do a wet test next since your dry cranking is inconclusive. If your results are still down I'd do cylinder leakage to narrow down the problem. |
| Bill Rowles
12-26-2012 12:46:19
76.2.232.2
| Have you run the engine since the rebuild/overhaul work? Approximately how many hours? Did you adjust the valve stem clearance between cam/lifter and valve after grinding valves? What clearance settings did you use there? |
| Jerry/MT
12-26-2012 09:25:19
206.183.116.145
| Make sure that your valves aren"t sticking, a chronic problem with under used N series tractors. |
| old
12-26-2012 08:45:59
209.86.226.32
| Did you use a good assembly lube when you installed all the parts?? ring on so as to not have the gaps line up?? And of course if you used the old sleeves and new rings did you measure so as to make sure the new rings would even fit right and have the correct end gap in the bore |
| JMOR
12-26-2012 07:09:23
72.181.173.171
| Quoting Removed, click Modern View to seenew rings in old sleeves? Did you run it in before taking measurements? Lapped??.....check for seal afterwards? |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
