schematic and parts #s of hydrualic pump of loader 1841 ford
I desperately need the schematic diagram and corresponding part numbers for the hydrualic pump for the front loader on a 1841 ford tractor
Help!!!!
<a href="http://www.external_link/NHC/8431.aspx" target="_blank">Click Here</a> for complete parts diagrams for your industrial tractor.
By the way, this is the Ford N Board. In the future I would ask questions about this model over on the <a href="http://www.ytmag.com/ford/wwwboard1.html" target="_blank">Ford Board.</a>
Good luck.
(quoted from post at 20:44:20 12/22/12) I desperately need the schematic diagram and corresponding part numbers for the hydrualic pump for the front loader on a 1841 ford tractor
Help!!!!
Does your loader have it's own dedicated pump mounted in front of the engine or does it run off the tractor's hydraulic system/pump? The pump UD linked for you is the one for the tractor. Do you have a model number for the loader?
TOH
1841 was the heavy industrial. It had a front mounted pump and seperate reservoir for oil in the nose.
Dunno what the loader model was. It was very specific to the 18xx and 41xx tractors as it tied in to the massive sub frame and also to the steering column (remember the fly by wire one?)Fellows on the Ford board could say.
(quoted from post at 22:56:36 12/22/12) 1841 was the heavy industrial. It had a front mounted pump and seperate reservoir for oil in the nose.
&lt;img src="https://photos.yesterdaystractors.com/gallery/tphotos/a11578.jpg"&gt;
I found several posts saying it was the 712 loader. I couldn't find squat about it on the CNH parts website. Lots of info for the 730 series however.
TOH
I have several of these TLB. If you can send your email address I will send you the pages you need.
My email is open.
Kirk
My 1801 series Owner's Manual states that the 712 Loader was optional on these tractors.
Hi, I have an 1841. If you need parts for the hydraulics let me know as I will be parting out probably in the next month or so.
