TractorLinks.com
Order Ford 8N Parts Online
Re: 8n brake spring
Bruce (VA)
12-23-2012 18:47:52
You don't need the third spring to "makeit work" on the right side. If you have an extra, it's helpful, but it will work as designed w/ 2.
Check out the position of the adjusters in the pics.
Money Pit
12-24-2012 03:27:33
 Re: 8n brake spring in reply to Bruce (VA), 12-23-2012 18:47:52
OK; you got me curious; why the reverse position of the adjuster from one side to the other?
Bruce (VA)
12-24-2012 06:02:32
 Re: 8n brake spring in reply to Money Pit, 12-24-2012 03:27:33
Put them in backwards & the adjuster is next to impossible to reach w/ a tool.
jammison
12-24-2012 06:46:44
 Re: 8n brake spring in reply to Bruce (VA), 12-24-2012 06:02:32
OK, so then, why did they put the adjuster slot high on the right & low on the left side???
Hobo,NC
12-24-2012 19:35:25
 Re: 8n brake spring in reply to jammison, 12-24-2012 06:46:44
My guess with out confirming it theirs only one part # for the backing plates...
ASEguy
12-25-2012 05:17:55
 Re: 8n brake spring in reply to Hobo,NC, 12-24-2012 19:35:25
You're probably right Hobo. Remember the older GM's, I think it might have been the Monte Carlo, that had the e-brake cable going through the backing plate from the primary shoe side?
