| Ford 9N, 2N & 8N Discussion Forum |
Topic: What is it??
[Return to Forum]
| Author |
[Modern View]
| John E/Pa
12-22-2012 07:29:19
75.88.180.126
Have a slight problem,an 8N front mount,12 volt that I bought recently,when I try to hook the positive cable to the battery the starter turns over,so I,m thinking its possibly the selinoid, or the switch or what else could it be, in need of some guideance,thanks, dumb guy from pa. |
| Royse
12-22-2012 14:04:13
69.36.49.151
Re: What is it?? in reply to John E/Pa, 12-22-2012 07:29:19
| Sounds like you found it. Buy a good replacement solenoid.
I've had that happen a couple of times on cheap ones like from TSC, etc. |
| John E/Pa
12-22-2012 13:44:55
75.88.180.126
| Ok, just came back from garage, checked wire from push button to selinoid,one spot was rubbed thru but not touching any where that I could see,so decided to replace wire as Dell sugested,still no help so taped the top of selinoid with a small hammer like Royse suggested, guess what it worked some times, think I will just replace the selinoid, thanks to everyone for all the suggestions,this is great site, John from Pa |
| soundguy
12-22-2012 17:37:29
184.247.42.95
Re: What is it?? in reply to John E/Pa, 12-22-2012 13:44:55
| contacts got welded.. usually from low bat power.. |
| Dell (WA)
12-22-2012 10:53:56
63.226.219.87
| John........yer starter mounted 3-terminal solenoid is operated by GROUNDING the BIG thumb switch by yer tranny shifter. The little middle terminal should face yer tranny. Most likely yer big CLODD-HOPPERS kicked the solenoid wire where it goes thru the bottom of yer sheetmetal dashboard. Don't fight it, byte the bullet and REPLACE it with NEW 14ga stranded INSULATED (enny color, electrons don't care about color) wire with correct terminals. Simple, eh? .......Dell, a 12V advocate for the right reasons |
| Royse
12-22-2012 07:47:41
69.36.49.151
| Assuming you have the correct 3 post solenoid still hooked up to the push button,
disconnect the little wire.
The one from the push button to the small terminal on the solenoid.
Does it still do it?
If not, that small wire may have rubbed somewhere and grounded out,
or you could have a bad switch.
If it does, you may have a stuck solenoid. Sometimes they'll unstick
if you rap them with a screwdriver handle.
Let us know what you find. |
| cooter143
12-22-2012 07:34:20
174.125.42.6
| First thing I would check is to see if the wire running to the starter button has shorted to ground somehow, or that the starter button was fully disengaged. Starter turns when it is grounded, I wouldn't think it was the solenoid. Someone with more detailed troubleshooting will probably post and help you out.
This post was edited by Cooter143 at 07:42:57 12/22/12. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
