| Ford 9N, 2N & 8N Discussion Forum |
Topic: Ford 2N possibly burning coils up
[Return to Forum]
| Author |
[Modern View]
| Mark over in Iowa
12-21-2012 20:44:04
173.24.210.219
I have a 1942 Ford 2N. It has a 12 volt conversion with a 12 volt coil and one OEM resister in it. I have went through my third coil. The tractor will initially run for about 1/2 hours. Then it quits and does not want to run again. After it rests for about a day or so, sometime it will restart and run for 20 to 30 minutes again. When you restart it, it will idle ok in neutral but as soon as you put it in gear and bring off the clutch, it bogs out and dies. Any ideas????? ( I have left the swtitc on a few times but can not conclude if this is connected to when the coils have burned up.) Mark |
| R Geiger
12-25-2012 07:53:49
50.39.151.117
Re: Ford 2N possibly burning coils up in reply to soundguy, 12-21-2012 20:44:04
| Quoting Removed, click Modern View to see
Have you checked for fuel flow? |
| Dell (WA)
12-22-2012 11:14:54
63.226.219.87
Re: Ford 2N possibly burning coils up in reply to Mark over in Iowa, 12-21-2012 20:44:04
| | Mark.........do NOT ever by-pass the "infamous ballast resistor", otherwize yer squarecan ignition coil internal insulative tar will MELT and short out some turns and cause weak sparkies. It takes about 1-hr for the insulative tar to melt, and about 4-hrs for it to re-solidify. Does that sound familiar??? ( I have left the swtitc on a few times but can not conclude if this is connected to when the coils have burned up.) ........umm? You do know ONLY the key operated ignition switch powers the ignition coil, don't you??? Leaving the ignition switch ON, will definitely MELT yer squarecan insulative tar and cause weak sparkies. Many shade tree mechanics actually miss-wire the 3-terminal board under the amp-meter that the ballast resistor is mounted on and un-intentionally OVER VOLT the squarecan coil, melting its insulative tar. Also check yer 4-nipple wiring; 1,2,4,3 CCW. Many shadetree mechanics gitt sparkies 4&3 swapped. The N-Engine is SOOooo GOOoood it will start and run on just 2-sparkies and won't have enuff hair on its chest to pull the top off'n a soda can. Just as you complain. .......Dell, yer self-appointed sparkie-meister |
| Mark over in Iowa
12-25-2012 05:09:43
63.152.34.58
Re: Ford 2N possibly burning coils up in reply to Dell (WA), 12-22-2012 11:14:54
| | I have not bypassed the resistor, it is wired correctly. The 1243 is also hooked up properly. How would I know if the ammeter or 3 board is improperly wired which would overpower the coil? I have also ordered another 12 volt coil, it"ll be here in a few days. |
| JMOR
12-25-2012 06:41:02
72.181.173.171
Re: Ford 2N possibly burning coils up in reply to Mark over in Iowa, 12-25-2012 05:09:43
| BillM (OH)
12-22-2012 09:49:06
173.81.81.180
| Sound like typical coil failure symptoms. Runs for a good while and then shorts out & restarts after cool down. Ignition switch failure usually quits in a shorter time. Leaving switch on will fry the coil sooner or later - might want to change points also, as it doesn't help them any either. |
| Den N Ms
12-22-2012 06:56:24
184.41.137.166
| Is the OEM resistor wired up correctly?Coil should get power through the OEM resister. |
| Plane Bart
12-22-2012 05:54:28
184.199.28.114
| Check the switch or better yet bypass it with a jumper wire and see if you get spark if so replace the switch |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
