Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Clutch RR
Paul in MN
12-21-2012 19:35:26
Colin,
Contact me when you get close to doing the job. I'll give you a contact for a clutch guy who many of the big companies use and then they double his price to you. I have used him before and found him quite reasonable and very accomodating. He also has the needed bearings at reasonable cost, and he looks for quality parts.
When you do the clutch, check the starter ring gear very carefully for damaged or missing teeth. The 4 cylinder engine usually stops against compression in only 2 places on the ring gear, 180 deg apart. I have had to replace ring gears along with clutches, and have 1 or 2 N tractors sitting now needing clutches and ring gears, plus an IH 300 needing the same thing. My barn is just too cold for me to work on them now. I covet your shop!
Merry Christmas to both of you.
Paul in MN
Colin King
12-22-2012 16:20:25
 Re: Clutch RR in reply to Paul in MN, 12-21-2012 19:35:26
Hi Paul,
It is darned cold for working outside. I spent a an hour in the shop this afternoon - not long enough to justify lighting a fire - and my hands are telling me they didn't like that. My shop is a beast to heat. It's not insulated and on a day like today when the high is in the low 20s, the best I can expect is about 50 degrees. Plenty warm to work in, but not good for painting, etc, and not easy on the firewood pile.
Thanks for the advice on the ring gear. I will also drop you a line for that fellow's contact info when I get to the clutch.
Colin
Copyright © 1997-2015 Yesterday's Tractor Co.
