Maybe someone can point me in the right direction. I went out to plow the 10 inches of snow that we got yesterday and pulled the tractor out of the heated shop and it worked for about 1 minute and began to sputter/die out and would completely quit. The tractor would restart and work again for a few minutes and then sputter and die out. After letting it rest for several minutes it would run fine for a minutes and again die out. I changed the spark plugs thinking that the plugs were fouling. It didn"t make a difference. I checked the fuel - no apparent problem. It was still snowing when I was out and seems to be a problem with the electric system - coil or points. I plowed a week earlier with it and it ran like a champ. Any direction/advice would be appreciated.
Thank you!
Thank you!
