land leveler
egbinor
I"m looking to build a land leveler for my 8N. I"ve been told the best kind is one that hooks to the 3 Point and has caster wheels 8 ft behind the blade. Looking to level my gravel drive way. Any ideas or pictures out there? I have a 3 Pt blade but not good enough to get good results with it! Any help appreciated. EGBinOR
Don't have pictures but I made a frame about three feet behind the back blade with wheels. Used chains to set depth with 9N. I built about 1/4 mile road and covered it with Waste asphalt. Worked very good. can send pic if you want.
You can build a frame and add the wheels to your current back blade.
I don't have a picture, but I built a set like this for my landscape rake.
It worked well and I just pinned them on so I could take them off when not needed.
Kind of like this guy did: Someone else's
I saw a setup once, nothing much more than a 3 point out the back side of a blade going back about 4-5 feet to a single wheel about wheel barrow sized. As I recall only the top link was adjustable. It was probably a 7 ft blade and 30+ hp tractor. The top link forked at the wheel end.
I make a position/height control device for the 9N/2N and Ferguson T model tractors that gives you positive positioning of the lift arms. Set and forget it.
About a thousand sold in the past 10 years or so.
See my link below.
Zane
ZANES LIFT STUFF
(quoted from post at 21:16:35 12/16/12) I"m looking to build a land leveler for my 8N. I"ve been told the best kind is one that hooks to the 3 Point and has caster wheels 8 ft behind the blade. Looking to level my gravel drive way. Any ideas or pictures out there? I have a 3 Pt blade but not good enough to get good results with it! Any help appreciated. EGBinOR
ne man's work:
Thanks for the pic JMOR and to all the others that replied. Just what I was looking for, wish the John Deere forum worked as well. EGBinOR
(quoted from post at 12:51:29 12/17/12) Thanks for the pic JMOR and to all the others that replied. Just what I was looking for, wish the John Deere forum worked as well. EGBinOR
In this case, at least, JD costs the same! :lol:
(quoted from post at 16:48:37 12/18/12) zane has best answer
t is an answer, but to a different problem than egbinor is trying to solve. Good position control does not make a leveling machine. Think road grader, with blade positioned BETWEEN the axles.
(quoted from post at 14:39:45 12/18/12)
Exactly. Without that rear wheel or wheels in back of the blade, every time your wheels hit a low spot the blade goes down with the wheels. Those rear wheels hold it at a steady level.
JMOR, of course you know this. I'm just adding a little more for those that don't get it.
(quoted from post at 16:56:19 12/26/12)
(quoted from post at 07:36:53 08/17/12)
[/URL]
Here is a driveway grader I just completed. I have the plans available.
One thing I would advise, make it as heavy as your tractor can handle. I have read that 110 lbs per foot of width is recommended, and after using it, I would agree. This one is 6' wide. The wheels on my 8N were just starting to lose traction when I was dragging this up a slight hill in the gravel. I lifted the 3PH just a bit, which put more weight on the tractor, and all was good. This thing does an excellent job at smoothing out my 1/2 mile gravel driveway.[/img]
/quote]
