Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: land leveler
Phlash in OK
12-16-2012 17:23:03
Don't have pictures but I made a frame about three feet behind the back blade with wheels. Used chains to set depth with 9N. I built about 1/4 mile road and covered it with Waste asphalt. Worked very good. can send pic if you want.
12-16-2012 19:13:26
 Re: land leveler in reply to Phlash in OK, 12-16-2012 17:23:03
I make a position/height control device for the 9N/2N and Ferguson T model tractors that gives you positive positioning of the lift arms. Set and forget it.
About a thousand sold in the past 10 years or so.
See my link below.
12-18-2012 12:48:37
 Re: land leveler in reply to ZANE, 12-16-2012 19:13:26
zane has best answer
12-18-2012 13:39:45
 Re: land leveler in reply to wlc1, 12-18-2012 12:48:37
Quoting Removed, click Modern View to seeIt is an answer, but to a different problem than egbinor is trying to solve. Good position control does not make a leveling machine. Think road grader, with blade positioned BETWEEN the axles.
12-19-2012 20:13:10
 Re: land leveler in reply to JMOR, 12-18-2012 13:39:45
Exactly. Without that rear wheel or wheels in back of the blade, every time your wheels hit a low spot the blade goes down with the wheels. Those rear wheels hold it at a steady level.
JMOR, of course you know this. I'm just adding a little more for those that don't get it.
