TractorLinks.com
Show Parts for Model:
land leveler
EGBinOR
12-16-2012 17:16:35
I"m looking to build a land leveler for my 8N. I"ve been told the best kind is one that hooks to the 3 Point and has caster wheels 8 ft behind the blade. Looking to level my gravel drive way. Any ideas or pictures out there? I have a 3 Pt blade but not good enough to get good results with it! Any help appreciated. EGBinOR
JMOR
12-17-2012 06:13:03
 Re: land leveler in reply to EGBinOR, 12-16-2012 17:16:35
Quoting Removed, click Modern View to seeone man's work:
EGBinOR
12-17-2012 08:51:29
 Re: land leveler in reply to JMOR, 12-17-2012 06:13:03
Thanks for the pic JMOR and to all the others that replied. Just what I was looking for, wish the John Deere forum worked as well. EGBinOR
Royse
12-17-2012 18:33:16
 Re: land leveler in reply to EGBinOR, 12-17-2012 08:51:29
In this case, at least, JD costs the same! :lol:
HCooke
12-17-2012 05:28:24
JMOR has a good picture of one. I don't have a copy of it.
russb wa
12-16-2012 18:59:43
I saw a setup once, nothing much more than a 3 point out the back side of a blade going back about 4-5 feet to a single wheel about wheel barrow sized. As I recall only the top link was adjustable. It was probably a 7 ft blade and 30+ hp tractor. The top link forked at the wheel end.
showcrop
12-16-2012 18:58:34
Caster wheels are the right set up for leveling but 8ft is a little extreme.
Royse
12-16-2012 17:46:56
You can build a frame and add the wheels to your current back blade.
I don't have a picture, but I built a set like this for my landscape rake.
It worked well and I just pinned them on so I could take them off when not needed.
Kind of like this guy did: Someone else's
This post was edited by Royse at 17:50:46 12/16/12.
Phlash in OK
12-16-2012 17:23:03
Don't have pictures but I made a frame about three feet behind the back blade with wheels. Used chains to set depth with 9N. I built about 1/4 mile road and covered it with Waste asphalt. Worked very good. can send pic if you want.
ZANE
12-16-2012 19:13:26
 Re: land leveler in reply to Phlash in OK, 12-16-2012 17:23:03
I make a position/height control device for the 9N/2N and Ferguson T model tractors that gives you positive positioning of the lift arms. Set and forget it.
About a thousand sold in the past 10 years or so.
See my link below.
Zane
wlc1
12-18-2012 12:48:37
 Re: land leveler in reply to ZANE, 12-16-2012 19:13:26
zane has best answer
JMOR
12-18-2012 13:39:45
 Re: land leveler in reply to wlc1, 12-18-2012 12:48:37
Quoting Removed, click Modern View to seeIt is an answer, but to a different problem than egbinor is trying to solve. Good position control does not make a leveling machine. Think road grader, with blade positioned BETWEEN the axles.
Caryc
12-19-2012 20:13:10
 Re: land leveler in reply to JMOR, 12-18-2012 13:39:45
Exactly. Without that rear wheel or wheels in back of the blade, every time your wheels hit a low spot the blade goes down with the wheels. Those rear wheels hold it at a steady level.
JMOR, of course you know this. I'm just adding a little more for those that don't get it.
