| Ford 9N, 2N & 8N Discussion Forum |
Topic: Re: Steering tutioral- 8N
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Ultradog MN
12-16-2012 12:12:18
184.100.109.75
I think you have an 8N but we'll need to know if you have the early style steering box or the later one. Also, I'm not sure what you mean by a 7' scoop. Is the scoop mounted in front or back? Generally though, loose or wobbly front tires are caused by one or more of the following: Worn tie rod ends, Steering box out of adjustment, Improper toe in Worn spindle bushings. Even things like loose balls in the radius rod caps, badly bent radius rods and or a worn out center axle bushing can cause them to wobble or feel loose. |
| R L Dick
12-16-2012 20:24:11
67.160.91.67
Re: Steering tutioral- 8N in reply to Ultradog MN, 12-16-2012 12:12:18
| Had a shimmy ,replaced spindal pins and bushings,radis rod front pina put a penny in each rear radis rod end,set tow on each side. added a extra spacer on center pivot,no more shimmy or wobble.as i am retire and have a lot of time this is fun not work. hope this info helps ..Richard in Poulsbo, WA |
| Den N Ms
12-16-2012 13:44:15
74.177.29.94
| Also check first for loose or worn wheel bearings. |
| Mr. T. Minnesota
12-16-2012 12:22:37
68.170.114.158
| Ultra, Should have noted it is an early model 8N. I believe it is either a '47 or '48. The seven foot scoop is a front mount that fits Deerborn lift arms. It was ideal with this last wet snow we had in central Minnesota. Between the half tracks and the a full scoop of wet snow, it put the 8N to task. Glad you noted the possibilities with the front end.Will check that over too. Any other thoughts are welcome. Mr. T. Minnesota |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
