Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Steering tutioral- 8N
[Return to Forum]
Mr. T. Minnesota
12-16-2012 11:41:51
68.170.114.158
Forum Members,
Have read through the FO-4 manual on steering adjustments. The last time I saw backlash was on a Zebco fishing reel in northern Minnesota 50 years ago:)
Before doing anything, maybe the forum can tell me if I am headed in the right direction. The symptoms are when pushing a lot of snow with a 7 foot scoop and half tracks the front wheels seem to lift slightly and wobble at least an inch side to side. They are loose and there seems to be play in the steering wheel. What is the shortest and best method to cure the problem? Any thoughts are welcome!
Mr. T. Minnesota
[Reply]   [No Email]
Ultradog MN
12-16-2012 12:12:18
184.100.109.75
 Re: Steering tutioral- 8N in reply to Mr. T. Minnesota, 12-16-2012 11:41:51
I think you have an 8N but we'll need to know if you have the early style steering box or the later one.
Also, I'm not sure what you mean by a 7' scoop.
Is the scoop mounted in front or back?
Generally though, loose or wobbly front tires are caused by one or more of the following:
Worn tie rod ends,
Steering box out of adjustment,
Improper toe in
Worn spindle bushings.
Even things like loose balls in the radius rod caps, badly bent radius rods and or a worn out center axle bushing can cause them to wobble or feel loose.
[Reply]  [No Email]
R L Dick
12-16-2012 20:24:11
67.160.91.67
 Re: Steering tutioral- 8N in reply to Ultradog MN, 12-16-2012 12:12:18
Had a shimmy ,replaced spindal pins and bushings,radis rod front pina put a penny in each rear radis rod end,set tow on each side. added a extra spacer on center pivot,no more shimmy or wobble.as i am retire and have a lot of time this is fun not work. hope this info helps ..Richard in Poulsbo, WA
[Reply]  [No Email]
Den N Ms
12-16-2012 13:44:15
74.177.29.94
Also check first for loose or worn wheel bearings.
[Reply]  [No Email]
Mr. T. Minnesota
12-16-2012 12:22:37
68.170.114.158
Ultra,
Should have noted it is an early model 8N. I believe it is either a '47 or '48. The seven foot scoop is a front mount that fits Deerborn lift arms. It was ideal with this last wet snow we had in central Minnesota. Between the half tracks and the a full scoop of wet snow, it put the 8N to task.
Glad you noted the possibilities with the front end.Will check that over too. Any other thoughts are welcome.
Mr. T. Minnesota
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
