TractorLinks.com
Show Parts for Model:
Re: To Free a Stuck Engine
MisterT
12-16-2012 07:16:27
Yes, you CAN remove the crankshaft from a stuck engine. First, Remove the rod caps from the 2 rods that are easy to access. Second, remove the main caps. It will take a bit of doing, but now you should be able to lift the crank up and out of the journals just enough that it can be rotated 90, which will give access to the other two rod caps. Anyhow, that method worked on a severly stuck Farmall H engine.
