| Ford 9N, 2N & 8N Discussion Forum |
Topic: 9N Hydraulics not lowering
[Return to Forum]
| Author |
[Modern View]
| FiremanKyle
12-15-2012 20:22:09
99.23.216.52
Got my Dad's 42 9N back after some time and putting some investment into it (new sleeves along with 12V conversion) to get it running good. But running it, there appears to be a hydraulic issue. The Hydraulics goes up and is at full tension, it does not appear to want to come down. So looking through previous post and seeing a Zane comment about a 8N potentially a Exhaust valve. The oil is low currently and I dont"t think it has been changed (at least not within the last 30 years) so should the cleaning take care of it? It did sit for some time so (I will check this with an inspection). |
[Reply] [No Email] | |
| ASEguy
12-16-2012 03:46:20
68.186.162.134
Re: 9N Hydraulics not lowering in reply to FiremanKyle, 12-15-2012 20:22:09
| Mine 8N did pretty much the same thing. Exhaust valve was stuck. I pulled the pump, freed up the exhaust valve, replaced the safety valve and reinstalled the pump with a new gasket. works great now. |
| Jerry/MT
12-16-2012 12:52:45
206.183.116.145
Re: 9N Hydraulics not lowering in reply to ASEguy, 12-16-2012 03:46:20
| The 9N does not have a separate exhaust valve like an 8N. The OEM 2N and the 9N use the Ferguson System and the 8N uses a different control scheme. |
| ScoutB
12-16-2012 16:36:23
69.214.10.206
Re: 9N Hydraulics not lowering in reply to Jerry/MT, 12-16-2012 12:52:45
| I just got my 40 9N running too and I had the same problem. After sitting still for 20 years I assumed it was a stuck valve. When I shut it down the back blade would eventually drop to the ground, usually overnight. I went out to mess with it today and lifted the control lever just enough to start the blade up, then dropped it again. I did that 10 or 12 times and everything freed up! I used the blade for about an hour afterward and it worked perfectly. Sometimes it's better to be lucky than good. Maybe you'll be lucky too. I do plan to change the fluid now. |
| Jerry/MT
12-15-2012 22:17:11
206.183.116.145
| The 9N has the Ferguson System. You may have a stuck control valve. Open the hydraulic comapartment access plate and reach in the oil and pull back on the "T" shaped control valve stem and see if it drops. DO NOT STICK YOU HANDS IN THE COMPARTMENT IF THE ENGINE IS RUNNING AND THE PTO IS CONNECTED! |
| Jason S.
12-16-2012 06:12:44
174.252.158.181
Re: 9N Hydraulics not lowering in reply to Jerry/MT, 12-15-2012 22:17:11
| My lift would stick in the up position in my Ferguson. I replaced the control valve and it fixed it. Even though my old control valve was in good shape at some point in its life water had got into the hydraulic pump and had caused some very small pits and discoloration in the surface of the control valve. Believe it or not that will cause it to stick. If the control valve doesn"t have a smooth almost mirror finish to it, it will stick. Sometimes you can use a metal polish and buff it back up but dont sand it that will make it worse. Also if the spring that hooks from the control fork to the lift cylinder is broken or stretched really bad it can cause the lift to stick in the up position. But its usually the control valve or a stuck valve in the pump that causes it. |
| Royse
12-15-2012 20:44:11
69.36.49.151
| Quoting Removed, click Modern View to see
It won't hurt. Except maybe the wallet.
When I got my 2N the hydraulics would stick all the way up and not come
down until I shut the tractor off for a while, then they would just fall.
I cleaned it all up, put new fluid in it and worked it.
Haven't had that problem return for over a year and a half now.
YMMV and it's a ~$50 gamble! |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
