Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: To Free a Stuck Engine
[Show Entire Topic]  [Return to Forum]
ZANE
12-15-2012 18:51:26
98.83.71.37
The best way I have ever found to un-stick a stuck engine is using a process I came up with years ago. I have a cheap air impact chisel that I put a blunt tool in. I cut out a round piece of 3/8" plate about 2-1/2" diiameter round and welded a big 1/2" nut in the middle.
All you have to do is place the plate with nut in the middle of the piston and then the impact tool in the middle of the nut and start hammering. Some type of penetrant should be used around the piston. You will be able to tell when the piston begins to move in the bore because it will start to wiggle where it didn't when you first started vibrating on it. Go the next piston and do the same thing till each piston is free. Once you get all of them free have somebody put pressure on the crankshaft trying to turn it while vibrating on one of the pistons that ia about half way down the bore.
It will work!
Zane
[Reply]   [No Email]
Fuddy Duddy
12-16-2012 05:17:21
75.221.140.205
 Re: To Free a Stuck Engine in reply to ZANE, 12-15-2012 18:51:26
I like your idea. Now I've just got to find that air impact chisel. I've got one around here some where. Engine will have to be reworked. The guy had it for two years and it was three years into a rebuild. Guy said he never heard it knocking when a rod turned loose. Knocked a hole in the oil pan which is tin. An easy fix. I've look all around underneath. As far as I can see the block is OK. Crank looks OK too. But I wouldn't put it back together without taking it apart and giving it a complete going over.
Should be a fun project. And just what I need for all the Black Locust thorns I grow around here. I'ver already change the 2N to all steel. But it thews up the ground pretty good.
[Reply]  [No Email]
ZANE
12-16-2012 12:40:49
98.83.71.37
 Re: To Free a Stuck Engine in reply to Fuddy Duddy, 12-16-2012 05:17:21
When we see a black locust around here we dig it up immediately and burn it.
Zane
[Reply]  [No Email]
ZANE
12-15-2012 18:54:56
98.83.71.37
Allready had this in my files.
STUCK ENGINE
I have an old impact chisel tool. years ago I fabricated a round flat piece of 3/8" plate and welded a big deep nut in the middle of it. When I get a stuck engine I take the head off and pour diesel fuel on top of the pistons and them take the impact with a flat ended tool in it and sit my fabricated tool on top of the piston and let it hammer. I've never failed to loosen the worst stuck and rusted engine with this thing. The crank won't move with the first two or three but when that fourth one breaks loose it will usually begin to move the piston down. Believe it or not it will usually loosen the stuck rings too because they are what is stuck to the cylinder wall and the vibration will wiggle the loose most of the time. You can tell if the rings are free by looking down beside the piston at where the end gap is and wiggling the piston back and forth to see if the rings move.
Zane
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
