Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Two 6v batteries,12v charge
George Marsh
12-15-2012 12:21:49
Try placing a 12 volt headlight bulb in series with a 6v battery, say to the positive terminal. Connect the negative of the charger to the negative of the battery, the positive of the charger to the other side of the headlight bulb. The bulb will act as a resistor and you will have a 6v trickle charger using a 12v charger. May not work on a smart chargers. Do this when charging 6v batteries used on grandkids toys. By adding more bulbs in parallel with the first bulb, you will get more current. I find bulbs are a cheap power resistor. this way you can get a slow charge from a 12v charger.
