Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: higher compression ratio?
12-13-2012 15:13:02
shave an 8n head a lil.. then check valve clearance with putty and no head gasket.. then relieve as needed and bolt on.. that's about it.. as dean and the others said. other goodies not so available.
and the merc pistons in the parent bore.. well.. it works.. bat can cause issues later and requires overbore to correct.
also don't give you much more hP.
if you have an 8n and want more hp.. get a naa or 6xx ( or 8xx and have near 2x hp )
Bob Harvey
12-13-2012 15:39:47
 Re: higher compression ratio? in reply to soundguy, 12-13-2012 15:13:02
Or go the Baumann way and install a turbine/V-8/Valkirie !!
12-13-2012 16:06:35
 Re: higher compression ratio? in reply to Bob Harvey, 12-13-2012 15:39:47
yep.. jet engine HP :)
