Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Still Having Problems
TSWolf
12-12-2012 14:27:31
Everything is hooked up the same way as it was before I messed with it, and the same way it is on my 9N. I even tried the governor and the carb off the 9N, still with no result. Also, it's not that it runs at full speed when starting, it runs higher than it should.
old
12-12-2012 14:36:25
 Re: Still Having Problems in reply to TSWolf, 12-12-2012 14:27:31
Do as sound said then and take the linkage from the gov to the carb off and hold the throttle control closed. If it still runs way to fast you may have a vacuum leak in the manifold which can cause an engine to run faster then it should. If you can not slow it down by hand then you have a carb or manifold or other such problem
