Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Still Having Problems
[Return to Forum]
TSWolf
12-12-2012 11:19:17
70.192.193.242
Ok, so I rebuilt the carb, replaced the governor, and tuned up the 2N, plus replaced the head gasket, and it still over revs, what should I do now?
[Reply]   [No Email]
DanP
12-12-2012 15:56:18
24.60.126.220
 Re: Still Having Problems in reply to TSWolf, 12-12-2012 11:19:17
Vacumn leak? Cracked intake manifold or bad gasket?
[Reply]  [No Email]
TSWolf
12-12-2012 14:27:31
71.176.187.32
Everything is hooked up the same way as it was before I messed with it, and the same way it is on my 9N. I even tried the governor and the carb off the 9N, still with no result. Also, it's not that it runs at full speed when starting, it runs higher than it should.
[Reply]  [No Email]
old
12-12-2012 14:36:25
209.86.226.59
 Re: Still Having Problems in reply to TSWolf, 12-12-2012 14:27:31
Do as sound said then and take the linkage from the gov to the carb off and hold the throttle control closed. If it still runs way to fast you may have a vacuum leak in the manifold which can cause an engine to run faster then it should. If you can not slow it down by hand then you have a carb or manifold or other such problem
[Reply]  [No Email]
russb wa
12-12-2012 13:57:10
67.185.6.72
If you are saying that it starts at full speed?
It is almost certainly the carb or linkage.
The throttle plate is there to regulate the air
flow. It is mounted to a cross shaft. The shaft
is offset for the purpose of letting the throttle
plate which is bigger than the bore of the carb
(venturi) close against the bore because it can't
go past 90 degrees to the bore. Suction on the
throttle plate happens on both sides of the shaft,
so, since the plate has more area for suction on
the appropriate side there is constant force
trying to close the throttle.
It is possible you have somehow got the throttle
plate mounted on the wrong side of the shaft and
the throttle is being sucked open.
Give us some more detailed information, if nothing
else.
[Reply]  [No Email]
soundguy
12-12-2012 12:20:56
184.233.109.92
disconnect arm from governor to carb.. can you manually control throttle function at the butterfly
did you get all the connections to the right spots?
[Reply]  [No Email]
old
12-12-2012 12:04:21
209.86.226.19
Did you remove the throttle shaft and throttle plate when you did that rebuild??? If you did then did you get it back in correctly and did you put the throttle shaft back in correctly??? Does the linkage bind in any way?? Is the throttle control hooked up correctly??
[Reply]  [No Email]
Ultradog MN
12-12-2012 11:24:02
184.100.109.75
Sorry but I'm not much good with those Ns.
I will give you some general advice though.
Stop throwing parts at the tractor and find out what's wrong with it.
Then you can fix it.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
