TractorLinks.com
Show Parts for Model:
Re: dissappointing compression test
TheOldHokie
12-12-2012 10:11:00
I wasn't looking for concession - just a corroboration or correction I can trust :D Obviously the closer you can get to measuring the actual engine volume the better. Npw on to far less interesting tasks - fixing the coolant leak in TOOH's Cat. At least that has an outside chance of buying a little domestic tranquility.....
TOH
JMOR
12-12-2012 10:22:53
 Re: dissappointing compression test in reply to TheOldHokie, 12-12-2012 10:11:00
Quoting Removed, click Modern View to seeOn that coolant leak, first are you sure that you have a coolant leak? Have you checked your tire pressure? What is the position of the shifter when you observe this? I recommend a different viscosity coolant.
If all else fails, adding ATF to any opening that will accept it seems to be the primary fix....have you tried that? How is condenser & relief valve? Primed the oil pump lately?
TheOldHokie
12-12-2012 10:46:00
 Re: dissappointing compression test in reply to JMOR, 12-12-2012 10:22:53
Actually I have only taken TOOH's word for the coolant leak analysis. Perhaps it's really A/C condensate in December and she is actually pouring coolant into a drain tube.
TOH
