front mount distributor
boler76
in the centre of the offset drive tangs, there is a screw, what does it do? Mine will turn each way about 4 turns then stops. dont want to break it but wondering what it does? Thanks
(quoted from post at 21:25:34 12/11/12) in the centre of the offset drive tangs, there is a screw, what does it do? Mine will turn each way about 4 turns then stops. dont want to break it but wondering what it does? Thanks
hat is where Ford inserted a cylindrical fiber wick to hold oil that would gradually seep out the hole in the side of the shaft where it passes through the upper (front) distributor bushing. No need to remove that already staked & difficult to remove screw, just add oil with a squirt through the hole in side of shaft.
(quoted from post at 06:57:13 12/12/12) Thanks now I have learned something again today
ou are more than welcome. We never stop learning........can't help it. :wink:
