TractorLinks.com
Order Ford 8N Parts Online
Re: 8N Ford 6Volt to 12 Volt Conversion
Dell (WA)
12-11-2012 19:59:19
grabbatire........NO....NO....NO......the "infamous ballast resistor" is a special kind of resistor that changes value with heat. It starts out about 0.5-ohms and as it heats up (inna'bout 2-mins) it INCREASES in value to about 2-ohms. This is something you can NOT measure with common ohm-meter. But you can measure the effect on the top of your 1-terminal squarecan ignition coil with yer VOLT meter. Ittza LAW, Ohms Law.
The "infamous ballast resistor" is like yer lightbulb, it either works or it don't. So iff'n yer tractor starts, guess what??? Yer ballast resistor is working. .........Dell, yer self-appointed sparkie-meister
Mimos
12-13-2012 04:47:53
 Re: 8N Ford 6Volt to 12 Volt Conversion in reply to Dell (WA), 12-11-2012 19:59:19
Where can I find the manual that has Ittza LAW Ohms chart ?
JMOR
12-13-2012 06:17:19
 Re: 8N Ford 6Volt to 12 Volt Conversion in reply to Mimos, 12-13-2012 04:47:53
Quoting Removed, click Modern View to seeSame place you get the "8 ways to convert & they all work first time" list. Elusive. :wink:
