TractorLinks.com
Show Parts for Model:
Re: dissappointing compression test
carlntexas
12-11-2012 16:14:09
Gerard everything I know about compression testing i learned on the internet, mostly on this site. I did drive it and get it to operating temperature before testing, because that's what I read to do. Tractor is 12v and battery had full charge it was spinning fast.
ASEguy
12-12-2012 01:10:03
 Re: dissappointing compression test in reply to carlntexas, 12-11-2012 16:14:09
Carl, Yours sounds like relatively even wear for an older engine. If it's doing the job she's good to go. There are three compression tests that can be performed: dry cranking, wet cranking and running. If dry and wet cranking are inconclusive then cylinder leakage tests will isolate the leakage. Running compression tests the valve train for issues like bent pushrods, worn cam lobes "etc".
soundguy
12-12-2012 06:20:17
 Re: dissappointing compression test in reply to ASEguy, 12-12-2012 01:10:03
push rods, neat...
