Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Angle distributor
12-11-2012 14:59:52
Will it hurt well just figure it this way would you want to run your car that way?? As in over the long run it may in fact cause burned valves by the timing being off but that could take many many hour of operation. Your call as it could be as simple as some one using a points hold down bolt that is way to long and that can mess up timing. But as others have said the way your coming at this only serves to make it so people will not want to help you help your self. You get more flys with honey then you do with vinegar
12-11-2012 16:52:08
 Re: Angle distributor in reply to old, 12-11-2012 14:59:52
OK, sweetie, I will take that as a maybe. I was told I could get good answers here. U r the only one that tried. Manny thanks,
Love & kisses to all
Bob Harvey
12-11-2012 18:06:47
 Re: Angle distributor in reply to JoseinNM, 12-11-2012 16:52:08
Put the microphone down. Take the bees out of your 'Hive' and as I said just the other day, "G. F. Y." Hope this helps. BOB. If you can spell it backwards, you win a hand painted salami. Still B.
12-11-2012 17:43:29
Many many people here will help you and Dell did tell you how to check things out. I did tell you what may happen but then it may not happen. Either way it would be a good idea to do as Dell said and make sure what is wrong and also if you do not have it get an I-T FO-4 manual so you have info in hand
