TractorLinks.com
Show Parts for Model:
Re: Angle distributor
JoseinNM
12-11-2012 13:47:28
Look responses. That why I asked for experts. I only wanted to know if should do anything since operationally all is good. Maybe my bad. Maybe should said, will constant 20 hurt anything? No need to tell me stuck or inspect or won't start (I said it does) as those are clear to anyone. Happy idle too. Just simple yes or no from expert (one who really knows), can any damage be done at always 20 all the time?
Am I clear enough this time?
Manny thanks!
soundguy
12-12-2012 05:45:38
 Re: Angle distributor in reply to JoseinNM, 12-11-2012 13:47:28
yeah.. deffintely rude.. I agree with the other poster.
i know you want a yes no answer.. but .. if it really is advanced all the time.. I would expect harder to start conditions.. and at least a dragging starter eventually.
It takes mere moments to visually inspect a mechanical advance.
if you are afraisd to do that.. or don't know how.. just ask. Simple inspection / observation won't 'hurt' anyting, even if you chose to leave it that way.
Some are telling you that you will use the tractor at full throttle all the time.
that may be true.
it's not anywaher near true for me except when mowing. the other 50% of the work i do on a tractor is not at max throttle..
your call.
carlntexas
12-11-2012 16:45:24
Jose don't think your going about this the right way kind of rude and crude.
old
12-11-2012 14:59:52
Will it hurt well just figure it this way would you want to run your car that way?? As in over the long run it may in fact cause burned valves by the timing being off but that could take many many hour of operation. Your call as it could be as simple as some one using a points hold down bolt that is way to long and that can mess up timing. But as others have said the way your coming at this only serves to make it so people will not want to help you help your self. You get more flys with honey then you do with vinegar
JoseinNM
12-11-2012 16:52:08
 Re: Angle distributor in reply to old, 12-11-2012 14:59:52
OK, sweetie, I will take that as a maybe. I was told I could get good answers here. U r the only one that tried. Manny thanks,
Love & kisses to all
Bob Harvey
12-11-2012 18:06:47
 Re: Angle distributor in reply to JoseinNM, 12-11-2012 16:52:08
Put the microphone down. Take the bees out of your 'Hive' and as I said just the other day, "G. F. Y." Hope this helps. BOB. If you can spell it backwards, you win a hand painted salami. Still B.
old
12-11-2012 17:43:29
Many many people here will help you and Dell did tell you how to check things out. I did tell you what may happen but then it may not happen. Either way it would be a good idea to do as Dell said and make sure what is wrong and also if you do not have it get an I-T FO-4 manual so you have info in hand
Bob Harvey
12-11-2012 14:20:02
Yes & No.
Bruce (VA)
12-11-2012 14:16:10
" Am I clear enough this time?"
Yes, I think you are very clear.
Clear enough that you will probably not get another response from anyone here.
soundguy
12-12-2012 05:46:19
 Re: Angle distributor in reply to Bruce (VA), 12-11-2012 14:16:10
yeah.. quite rude.
I've written the name and ip down in my blacklist.. :)
