TractorLinks.com
Show Parts for Model:
Re: dissappointing compression test
TheOldHokie
12-11-2012 11:04:39
The purpose of doing a "wet" test after you get a low "dry" result is to identify the source of compression leakage. The reason you add the oil is it acts as a sealant around the rings. If the compression improves significantly after you add the oil - 40 PSI or more- it indicates the rings are leaking. If it only comes up a few PSI as is your case it indicates the rings are sealing fine and the major leakage is somewhere else. I think you are wasting your time with the ATF.
TOH
carlntexas
12-11-2012 12:47:25
 Re: dissappointing compression test in reply to TheOldHokie, 12-11-2012 11:04:39
old
12-11-2012 11:11:12
ATF will in fact help if it is a valve problem due to the fact valves stick and get carbon build up and ATF will remove some if not all the carbon if that is the problem.
