| Ford 9N, 2N & 8N Discussion Forum |
Topic: Re: dissappointing compression test
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| carlntexas
12-11-2012 10:32:27
69.46.56.208
old said: (quoted from post at 13:05:41 12/11/12) E-Bay and compression gauge why not buy local as in from an auto parts store?? Shoot some will rent you one and the real cost is you buy it and then you bring it back and get your $$ back.
That said it could be as simple as sticking rings or carbon build up. I would put say a 1/4 cup of ATF in each cylinder and let it sit a day then run it and after getting it warm do another compression check and I will almost bet them numbers come up a good bit | After seeing all the posts on here about soaking in ATF that was my thought it's been soaking for 3 days now. I don't need to use it for a while so I'm gonna go out and add some more ( when it warms up a little it was 24 degrees this morning ). When I go to start it up should I leave the plugs out and turn it over to blow ATF out or just start it and let it smoke.
This post was edited by carlntexas at 10:39:26 12/11/12. |
| old
12-11-2012 11:07:29
209.86.226.32
Re: dissappointing compression test in reply to carlntexas, 12-11-2012 10:32:27
| You will need to pull the plugs out and spin it over to clear out any excess ATF left in the cylinders if you have any that is. Some of the ATF will fall down threw the rings and then into the oil pan which will not hurt any thing since ATF is a simple oil that is very high detergent and that detergent is why it works well for many things and has even been proven to work better then things like PB blaster and Kroil |
| TheOldHokie
12-11-2012 11:04:39
74.110.72.184
| Quoting Removed, click Modern View to see
The purpose of doing a "wet" test after you get a low "dry" result is to identify the source of compression leakage. The reason you add the oil is it acts as a sealant around the rings. If the compression improves significantly after you add the oil - 40 PSI or more- it indicates the rings are leaking. If it only comes up a few PSI as is your case it indicates the rings are sealing fine and the major leakage is somewhere else. I think you are wasting your time with the ATF.
TOH |
| carlntexas
12-11-2012 12:47:25
69.46.56.208
Re: dissappointing compression test in reply to TheOldHokie, 12-11-2012 11:04:39
| Quoting Removed, click Modern View to see |
| old
12-11-2012 11:11:12
209.86.226.32
| ATF will in fact help if it is a valve problem due to the fact valves stick and get carbon build up and ATF will remove some if not all the carbon if that is the problem. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
