| Ford 9N, 2N & 8N Discussion Forum |
Topic: Chamferd Brakes now Hub
[Return to Forum]
| Author |
[Modern View]
| Money Pit
12-11-2012 02:32:58
12.45.43.66
You guys nailed it; axle splines are past the hub face. first surprise: got the 2 inch socket breaker bar and ext pipes to break the nut loose it came off with small force on the bar alone. nowhere near 450 lbs. second surprise: jacked it up thinking if it was in that far i could rock it loose instead of doing figure 8's / hub puller / heat. i lucked out and it worked which tells me it really was not tight anyhow.as long as i'll need the hub what else should i change while its apart? axle is hard so it should be ok? not getting any leakage so seals should be good. will i need to reshim the axle bearings? don't want to be going back into this in a year or two. thanks. |
[Reply] [No Email] | |
| soundguy
12-11-2012 12:38:49
173.105.146.15
Re: Chamferd Brakes now Hub in reply to Money Pit, 12-11-2012 02:32:58
| | get the hub for now. if you are lucky and the axle is not worn.. or not worn enough to make a difference.. you are at least good to go there. past that.. IF the axle is worn.. then you can burn that bridge when you see them splines on splines.. |
| Money Pit
12-11-2012 12:52:07
12.45.43.66
Re: Chamferd Brakes now Hub in reply to soundguy, 12-11-2012 12:38:49
| yes just getting a hub for now. i do respect the expirienced opinoins offered no doubt the axle could be a factor. hardened does not mean invincible.i'll know once it comes apart and i have the new hub in hand. maybe this weeknd i'll get my 2 hour brake job done. thanks again to all. |
| soundguy
12-12-2012 05:32:20
184.246.205.64
Re: Chamferd Brakes now Hub in reply to Money Pit, 12-11-2012 12:52:07
| | that's how them 2hr jobs happen. open something easy up and see thet 99% has to come apart.. :) post back |
| carlntexas
12-11-2012 07:05:53
69.46.56.208
| Both my hubs were worn as bad as yours and axles were ok. If the axle is bad I would try the shim trick before buying an axle,but that's just me I'm cheap. |
| Hobo,NC
12-11-2012 04:48:18
98.17.104.86
| Don't be surprised if the axles are worn out ... I have never seen were a hub was flopping around that did not ware the axle also... |
| Dean
12-11-2012 05:55:45
67.172.15.77
Re: Chamferd Brakes now Hub in reply to Hobo,NC, 12-11-2012 04:48:18
| | Agreed. Perhaps you can get away with replacing the hub only but you will not know until you install a new hub. Undersized hubs were once sold by Ford in several undersizes for situations such as this but these have been NLA for 25 years or more. Dean |
| JMOR
12-11-2012 04:48:12
72.181.173.171
| Quoting Removed, click Modern View to seeRemoving & replacing the axle shims does not alter the bearing shim/tightness/looseness.....unaffected. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
