Hi guys, I'm having a problem with my 9n draft lever springing upwards from the all the way down position. It happens every time with the tractor running or off. I havent taken anything apart yet, not exactly sure what to look for anyway.
also it should be noted this problem started when I was using a heavy blade. I lowered the draft lever and the blade did not lower on the first attempt (took several fully up/down throws of the lever). ever since then the lever springs back up to the halfway position!
lifting capacity does not seem to be affected.
any suggestions on where to start?
Thanks
-Clint
Thanks
-Clint
