I have a 1940 9N with a sauder loader.
I'm not sure if these parts go with the loader or not.
There is a Tee on the line that goes from the test port to the loader, and it plumbs the fluid back up, through a pushbutton valve, and into the reservoir.
What does this line do? When you push the button it lets the pressure off the loader, but it works the same without having to push the button..
I plugged the Tee and tried running the loader, it makes a squealing noise so I stopped running it and I'm going to put it back together, but I'm just curious why is it there and how does it work?
