TractorLinks.com
Show Parts for Model:
Re: HCooke--stumped
Ken(Ark)
12-09-2012 13:28:01
Does it have good suction ? With the elbow pipe off and the palm of your hand over the end of the carburetor , can you feel a strong suction ?
Usually I can keep a motor running with a spray bottle of gas or a can of starting fluid if it is a fuel problem .
If not it is usually spark or timing . The suction would be a good indicator on the timing of the valve opening/closing at the right time .
How about the valve clearance ? Probably not the problem but if they are too tight the compression will not build up enough to explode .
Last thought , burn off the spark plugs . Some times fouled plugs look good but if three are not sparking then it will only run a few seconds .
