| Ford 9N, 2N & 8N Discussion Forum |
Topic: Re: 9N Points
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Tackhammertime
12-09-2012 12:59:07
98.94.197.45
Are you using the three gaskets that go with the coil/ dist? My 47 2n sits in a shed with no heat 365 and starts every time. I always run it once a month. Points are three years old. |
| Connor
12-09-2012 13:03:09
208.101.170.146
Re: 9N Points in reply to Tackhammertime, 12-09-2012 12:59:07
| I have the cork gaskets for between the cap and dist., and for between the coil and dist. Where is the third one at? I thought there is one for between the block and the distributor, but I called my Ford dealer and he said no, and I couldnt find a gasket set online.. |
| old
12-09-2012 13:09:20
209.86.226.27
Re: 9N Points in reply to Connor, 12-09-2012 13:03:09
| Gasket between the block and the distributor one below the coil and one for the cap which gives you 3. Most of the time what causes the points to corrode is the fact that when the engine shuts down the points are closed so they in turn corrode due to touching each other. If you can figure out how to get them open when you park it then that would be a lot less of a problem. |
| Mike OH
12-09-2012 14:00:00
173.89.186.132
Re: 9N Points in reply to old, 12-09-2012 13:09:20
| Every time I shut down my 8N, I turn the key back on after the engine stops and watch the amp meter. If I see a negative deflection,(meaning the points are closed) I jog the starter button until the amp meter returns and stays at zero, before turning the key off. Then I know the points are open. I truly believe this practice has extended the life of my points. |
| old
12-09-2012 15:08:33
209.86.226.40
Re: 9N Points in reply to Mike OH, 12-09-2012 14:00:00
| Ya that works if your amp gauge works and or will move from the points being closed. I have seen many that doing that will no work |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
