Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: Late 8N rear hub
JMOR
12-09-2012 10:47:19
Quoting Removed, click Modern View to seeDave or Zane or both maybe, I think, has talked of using strips cut from hard banding strap material. I just get a new hub & axle when needed. It is most likely the back of the lug studs hitting, since they are rear most parts, so I'm not sure what material you would remove? If hub &/or axle are worn that much, then you run into situation where nut/washer tightens against axle shoulder & hub remains loose on splines. New hub & perhaps new axle to fix.
