TractorLinks.com
Order Ford 8N Parts Online
Re: 8N starting
old
12-09-2012 09:37:51
Pull the air intake tube off and make sure the choke is working as it should and the little plate that is held closed with the spring is there and the spring is there. Next hold you hand over the air intake an try to start it. You should both feel a good suction and also get gas on your hand. If you do not get both then you have sticking rings and you need to give it an ATF treatment which by the way would not hurt to do either way. By the way it just might try to start when you do that and if it does feather your hand over the carb air intake to keep it running and by doing so you may clear up the clog you have in the carb jets
