| Ford 9N, 2N & 8N Discussion Forum |
Topic: 8N starting
[Return to Forum]
| Author |
[Modern View]
| Jay in Va
12-09-2012 07:38:50
68.57.184.200
I have been out all year with broken leg, but trying to get ready for snow. 8n won"t start! Spray starter fluid into carb, fires right up. open drain on bottom of carb, fuel runs freely. Still struggling with crutches so working is difficult. Anyone have an extra magic wand? |
| Den N Ms
12-09-2012 11:04:46
74.177.23.85
Re: 8N starting in reply to Jay in Va, 12-09-2012 07:38:50
| Jay,Get it running again with the starting fluid.If you can keep it running by spritzing the starting fluid in the carb throat Then it is fuel related and the main jet has trash plugging it up.Try hand choking it over the carb throat if that don't clear it.It is plugged ,You might get it cleared out by removing the main jet needle and take a can of carb cleaner with the straw attached and sticl it way down the main jet needle hole and try blasting out the trash.Do not use compressed air to try to clear it out as that will damage the float. If that don't work the carb will have to be removed and cleaned .If the starting fluid doesn't keep it running then it is loss of spark.First try jumping the ignition switch,or try hot wiring it direct to the coil. |
| Jay in Va
12-10-2012 10:16:32
68.57.184.200
Re: 8N starting in reply to Den N Ms, 12-09-2012 11:04:46
| It appears to be not getting gas. Hand blocked the choke and no gas on my hand. Good flow to the carb though. |
| Jay in Va
12-09-2012 16:59:50
68.57.184.200
| Thanks guys. Tomorrow I will hobble out and try the various suggestions. Last Janurary she was purring. It is usually the simpliest of things. |
| Mike OH
12-09-2012 10:19:26
173.89.186.132
| First thing I would suspect is the gasoline. Has the same gas been in it for over a year? If so, drain it and put in fresh. Next thing I would suspect is the points. Clean them up a bit and recheck the gap. Good gas, good points, good spark, should run. |
| JMOR
12-09-2012 10:24:50
72.181.173.171
Re: 8N starting in reply to Mike OH, 12-09-2012 10:19:26
| Quoting Removed, click Modern View to see"Should" is the KEY word there........just ask HCOOKE! You should read his last week history on the other N board (two threads)! Talk about having eliminates possibilities! And still no run longer than a repeatable 3 seconds! |
| HCooke
12-09-2012 09:40:29
70.195.64.125
| | I've been struggling with one for a couple of weeks so I'm not sure I am qualified to help. Other posters are going to want to know if this is 6 or 12 volt and front or side mount distributor. I am going to ask if you have checked to spark. Sitting for a long time can cause corrosion on the points and weak or no spark. |
| old
12-09-2012 10:22:52
209.86.226.27
Re: 8N starting in reply to HCooke, 12-09-2012 09:40:29
| Reason I did not say anything about spark is because he said it runs on starting fluid so it almost has to be a clogged carb type problem LOL. So you still haven't got your running again?? You know your problem almost has to be one of those little things that once you find it you will be hitting your head on a wall thinking I should have checked that |
| HCooke
12-09-2012 09:40:01
70.195.64.125
| old
12-09-2012 09:37:51
209.86.226.27
| Pull the air intake tube off and make sure the choke is working as it should and the little plate that is held closed with the spring is there and the spring is there. Next hold you hand over the air intake an try to start it. You should both feel a good suction and also get gas on your hand. If you do not get both then you have sticking rings and you need to give it an ATF treatment which by the way would not hurt to do either way. By the way it just might try to start when you do that and if it does feather your hand over the carb air intake to keep it running and by doing so you may clear up the clog you have in the carb jets |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
