Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: HCooke--stumped
[Return to Forum]
dande man
12-08-2012 19:10:59
4.227.119.51
did you get it running if so what was the problem??
[Reply]   [No Email]
HCooke
12-09-2012 05:31:01
70.195.64.125
 Re: HCooke--stumped in reply to dande man, 12-08-2012 19:10:59
Not running yet. So far I have swapped the dist from a running tractor; I have swapped the carb from a running tractor; I have swapped manifolds. I replaced the manifold gaskets. I removed the valve cover gasket and observed the valves moving up and down - looked normal to me. I have hotwired the coil (bypassing the switch and the resistor). I have removed the exhaust pipe. I will run for about 3 sec if you spritz carb cleaner into the throat of the manifold and apply the choke.
[Reply]  [No Email]
soundguy
12-10-2012 07:26:46
184.245.227.145
 Re: HCooke--stumped in reply to HCooke, 12-09-2012 05:31:01
comp test?
[Reply]  [No Email]
Ken(Ark)
12-09-2012 13:28:01
173.187.227.94
Does it have good suction ? With the elbow pipe off and the palm of your hand over the end of the carburetor , can you feel a strong suction ?
Usually I can keep a motor running with a spray bottle of gas or a can of starting fluid if it is a fuel problem .
If not it is usually spark or timing . The suction would be a good indicator on the timing of the valve opening/closing at the right time .
How about the valve clearance ? Probably not the problem but if they are too tight the compression will not build up enough to explode .
Last thought , burn off the spark plugs . Some times fouled plugs look good but if three are not sparking then it will only run a few seconds .
[Reply]  [No Email]
Roland (AL)
12-09-2012 13:10:22
69.254.216.130
Hook up a temp fuel tank that might solve the problem.
Later Roland (AL)
[Reply]  [No Email]
Roger in Iowa
12-09-2012 06:35:18
166.182.3.51
Try another manifold.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
