Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Oil bath air breathers
Larry O
12-08-2012 17:10:27
Thanks Bruce for the quick reply that answers the part about the bottom one what about the top part on a through the hood 2N I guess it is the same ?
12-08-2012 18:19:05
 Re: Oil bath air breathers in reply to Larry O, 12-08-2012 17:10:27
Larry, I wish I had a definitive answer for you, but I don't.
Here's what I do have:
The through the hood air breather was a dealer installed option.
I have two of them, and my two are not the same.
One doesn't come apart at all on the top of the air breather, so no
place to put a gasket on that one.
The other one is held on with a metal band type hose clamp and
tapered metal to metal contact. No ridge to hold a gasket.
Maybe some did, some obviously did not.
Does yours have a place for a gasket or fit loose enough to put one in?
Larry O
12-09-2012 05:42:56
 Re: Oil bath air breathers in reply to Royse, 12-08-2012 18:19:05
Royse Mine is held on with a metal hat band and thumb screw like some of the lower cans there doesn’t seem to be a place for a gasket or seal but it is loose enough to very, very slowly rotate above half throttle maybe I have the wrong clamp Thanks Larry
Bruce (VA)
12-08-2012 17:21:06
Can't help you w/ the through the hood part.....8N's didn't have that option.
Harold or Chris or one of the other guys w/ 2 or 9N's will be along shortly w/ that answer.
Larry O
12-08-2012 17:21:52
 Re: Oil bath air breathers in reply to Bruce (VA), 12-08-2012 17:21:06
