Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 2N front axle
[Return to Forum]
jerry 2N
12-08-2012 16:04:34
184.19.89.26
I know that the 8N has a bushing or spacer in front and behind the axle at the pivot point why can't I use them on a 2N?
[Reply]   [No Email]
Ultradog MN
12-08-2012 17:49:44
184.100.109.75
 Re: 2N front axle in reply to jerry 2N, 12-08-2012 16:04:34
I sell worms - by the pound or the dozen - take your pick.
I never understood the reason for those washers as the radius rods are what hold the frone axle in position.
But from 1939 through 1985 or so Ford used that same wishbone front end and some of em had washers and some of em didn't.
Look it up if you doubt.
Generally if I find them on a tractor I'm working on I reinstall them.
But I don't fret if they aren't there.
For more infomation on worms;
[Reply]  [No Email]
Bob Harvey
12-08-2012 19:00:51
209.121.225.222
 Re: 2N front axle in reply to Ultradog MN, 12-08-2012 17:49:44
And your link is all you got on the mighty worm. Wikipedia has a better file also NatGeo. ;*)
[Reply]  [No Email]
Bob Harvey
12-08-2012 16:24:07
209.121.225.222
Hope you kept the lid for the can you just opened! ;*)
[Reply]  [No Email]
Den N Ms
12-08-2012 16:39:47
74.177.23.85
 Re: 2N front axle in reply to Bob Harvey, 12-08-2012 16:24:07
Yeh and it has 8 or 10 3/8 holes poked in the lid.
[Reply]  [No Email]
TOM N MS
12-08-2012 16:19:33
98.95.135.43
You can-I did..You will now see 97 different opinions--do whatever floats ur boat--It does work no matter what some will say..
[Reply]  [No Email]
TheOldHokie
12-08-2012 17:08:48
108.22.202.187
 Re: 2N front axle in reply to TOM N MS, 12-08-2012 16:19:33
The 2N was a mutt and came with multiple different front axle setups so that complicates the question somewhat. For the sake of discussion lets assume it's an early 2N with
  1. Cast bolster
  2. Radius rods hooked to the axle extensions.
I know you can put the spacers in there and bolt it up - it runs and it steers just fine. But my question (because I really don't know the answer although I have an educated guess) is:
Once assembled can you adjust the front wheel spacing from all the way in to all the way out without taking it apart to rearrange the spacers?
You can on an 8N.
TOH
[Reply]  [No Email]
Bob Harvey
12-08-2012 18:51:17
209.121.225.222
 Re: 2N front axle in reply to TheOldHokie, 12-08-2012 17:08:48
I guess my first attempt didn t go through. I thought we were talking about Center Pivot pin and stuff related. Not tie rods and such. Please advise. Thanks. B
[Reply]  [No Email]
Den N Ms
12-08-2012 17:12:17
74.177.23.85
The 9N/2N front end where the radius rods IS different from the 8N. The rad. rods on the 9N/2N attach to the adjustable axle arms, where the 8N rad. rods attach to the center axle section. When adjusting a 9N/2N's wheel spacing, the center axle section HAS to move fore and aft, unlike the 8N.
[Reply]  [No Email]
Bob Harvey
12-08-2012 18:54:28
209.121.225.222
 Re: 2N front axle in reply to Den N Ms, 12-08-2012 17:12:17
And oddly enough they are curved to allow for the widening. yipes.
[Reply]  [No Email]
TheOldHokie
12-09-2012 05:05:21
108.22.202.187
 Re: 2N front axle in reply to Bob Harvey, 12-08-2012 18:54:28
Bob Harvey said: (quoted from post at 22:54:28 12/08/12) And oddly enough they are curved to allow for the widening. yipes.
Not exactly my friend. That was my initial thought but the inner and outer axle segments are actually straight. The inner segment is simply bent in the middle to angle the ends rearward. That means pin holes in the outer axle segments will move along a straight line as the segments slide in/out. However the pin holes in the end of the radius rod will move along a circular arc as they are swung in/out.
Theorizing is always fun but I have a 9N sitting on jackstands with the axles unbolted and flopping in the breeze - easy enough to do a quick test right after I dispose of some country ham and eggs ;-) . Knowing how tight the pins fit into the holes my "educated guess" has not changed. Film at 11.
TOH - Myth Buster Wannabe
This post was edited by TheOldHokie at 05:06:52 12/09/12.
[Reply]  [No Email]
Bob Harvey
12-09-2012 09:33:55
209.121.225.222
 Re: 2N front axle in reply to TheOldHokie, 12-09-2012 05:05:21
AHA! and thanks for the schoolin'.
[Reply]  [No Email]
TheOldHokie
12-09-2012 07:11:53
108.22.202.187
 Euclid was right in reply to TheOldHokie, 12-09-2012 05:05:21
TheOldHokie said: (quoted from post at 09:05:21 12/09/12)
Top picture is with the wheels set all the way out, bottom picture is with the wheels set all the way in.
Myth Buster Findings:
  • The center front axle on the 9N/2N must be free to move .500+ fore and aft in order to allow front wheel spacing to be adjusted throughout the designed range.
  • Unlike the 8N using spacers on the axle pin to remove free space will necessitate removing the axle bolster to rearrange teh spacers when adjusting wheel spacing.
  • The .500 wide spacer used on the 8N will restrict the spacing adjustment possible to all the way in or to all the way out with little to no in between settings.
  • If you are going to use spacers avoid wide spacers and use multiple narrow spacers to provide intermediate adjustments
TOH
This post was edited by TheOldHokie at 08:39:51 12/09/12 4 times.
[Reply]  [No Email]
TheOldHokie
12-08-2012 17:54:57
108.22.202.187
I took plane geometry and I also own a 9N and an 8N.
Simple geometry says if the center section on a 9N/2N can't move the radius rod pins won't line up when you attempt to widen or narrow the wheel spacing.
Corollary to that theorem:
You can't get the pins in the 8N radius rods if you put the spacers in wrong.
Don't ask ;-)
TOH
[Reply]  [No Email]
jerry 2n
12-08-2012 18:48:57
184.19.82.14
 Re: 2N front axle in reply to TheOldHokie, 12-08-2012 17:54:57
thank you that is the answer.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
