TractorLinks.com
Order Ford 9N Parts Online
Re: 1947 9N Starting issues
jdlingerfelt
12-04-2012 12:48:52
I guess I wasted my time. If all of the continuity checks are OK, where can I look next. With the distributor installed on the tractor I never get spark. Believe it or not, this tractor used to run before I started messin' with it. I WILL NOT GIVE UP!
Bruce (VA)
12-04-2012 13:54:58
 Re: 1947 9N Starting issues in reply to jdlingerfelt, 12-04-2012 12:48:52
You've done all 4 continuity checks I suggested, correct?
Did you put the distributor & coil back on the engine as a unit?
Do you have battery voltage at the top of the coil?
Keep at it.......
jdlingerfelt
12-04-2012 18:37:45
 Re: 1947 9N Starting issues in reply to Bruce (VA), 12-04-2012 13:54:58
I installed the dist. both ways - coil on and coil off. No luck either way.
I have voltage to the top of the coil. I know I've read somewhere that the wire to the top of the coil must be a minimun size. Unfortunately I don't remember what. Is there any other component that might affect the spark, ie., the alternator?
BTW many, many thanks for taking the time to respond.
Bruce (VA)
12-04-2012 19:55:58
 Re: 1947 9N Starting issues in reply to jdlingerfelt, 12-04-2012 18:37:45
The alternator is in the charging circuit. It has nothing to do w/ ignition.
Don't worry about wire size; you either have battery voltage at the top of the coil or you don't.
Make sure the battery is fully charged. That's critical.
Do you have a spark checker or are you using an old plug?
In other words, tell me exactly how you are checking for spark.
jdlingerfelt
12-06-2012 11:36:39
 Re: 1947 9N Starting issues in reply to Bruce (VA), 12-04-2012 19:55:58
Bruce, I may have found the problem --I hope.
I was checking the connection of the coil to the dist. The spring was contacting the brass screw ok but I noticed the silver tab on the coil did not touch the contact "button" on the dist. cap. I tried bending the tab a little but I broke one off in the past so I'm very cautious now.
I'll keep trying to align the tab to the dist cap button.
Bruce (VA)
12-06-2012 13:19:04
 Re: 1947 9N Starting issues in reply to jdlingerfelt, 12-06-2012 11:36:39
Ahhhhhhh yes, tip # 5 on my list of 'frontmount failure points':
5. The tab on the bottom of the coil not making contact w/ the brass button on the cap. (With the cap on, the tab must firmly contact the brass button. No contact = no spark.)
Chances are you found the problem.
jdlingerfelt
12-06-2012 14:42:04
 Re: 1947 9N Starting issues in reply to Bruce (VA), 12-06-2012 13:19:04
Bruce,
I"VE GOT SPARK !!!
Getting it to start should be a piece of cake compared to what I"ve been thru,
Again, many thanks for sticking with me.
Joe L.
Bruce (VA)
12-06-2012 15:05:07
 Re: 1947 9N Starting issues in reply to jdlingerfelt, 12-06-2012 14:42:04
You're welcome. Glad to help.
Just don't flood it.
While each N has it's own starting sequence, none of them will start well by just yanking out the choke rod & holding it out for 5 or 10 seconds while the engine cranks. This is an updraft carb w/ a gravity fuel system; it is by it's very nature subject to flooding. Too much choke makes it happen.
Try this:
Key on, gas on 2 full turns, clutch in, 3/4 throttle, press the starter button. Let it crank for at least 3 - 4 seconds before you pull the choke rod. Then, don't hold it out for more than 2 or 3 seconds.
