Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 9N Parts Online
Re: 1947 9N Starting issues
Bruce (VA)
12-03-2012 14:15:40
" I don't seem to have continuity from the spark plug holes back to the brass screw when the points are closed."
Not sure I'm following you here.......
Are you checking for continuity between the holes in the distributor cap (where the plug wires insert) and the brass screw in the distributor?
Because if you are........you're wasting your time.
The rotor never touches the brass nipples in the cap. It's a HV connection.
jdlingerfelt
12-04-2012 12:48:52
 Re: 1947 9N Starting issues in reply to Bruce (VA), 12-03-2012 14:15:40
I guess I wasted my time. If all of the continuity checks are OK, where can I look next. With the distributor installed on the tractor I never get spark. Believe it or not, this tractor used to run before I started messin' with it. I WILL NOT GIVE UP!
Bruce (VA)
12-04-2012 13:54:58
 Re: 1947 9N Starting issues in reply to jdlingerfelt, 12-04-2012 12:48:52
You've done all 4 continuity checks I suggested, correct?
Did you put the distributor & coil back on the engine as a unit?
Do you have battery voltage at the top of the coil?
Keep at it.......
jdlingerfelt
12-04-2012 18:37:45
 Re: 1947 9N Starting issues in reply to Bruce (VA), 12-04-2012 13:54:58
I installed the dist. both ways - coil on and coil off. No luck either way.
I have voltage to the top of the coil. I know I've read somewhere that the wire to the top of the coil must be a minimun size. Unfortunately I don't remember what. Is there any other component that might affect the spark, ie., the alternator?
BTW many, many thanks for taking the time to respond.
Bruce (VA)
12-04-2012 19:55:58
 Re: 1947 9N Starting issues in reply to jdlingerfelt, 12-04-2012 18:37:45
The alternator is in the charging circuit. It has nothing to do w/ ignition.
Don't worry about wire size; you either have battery voltage at the top of the coil or you don't.
Make sure the battery is fully charged. That's critical.
Do you have a spark checker or are you using an old plug?
In other words, tell me exactly how you are checking for spark.
jdlingerfelt
12-06-2012 11:36:39
 Re: 1947 9N Starting issues in reply to Bruce (VA), 12-04-2012 19:55:58
Bruce, I may have found the problem --I hope.
I was checking the connection of the coil to the dist. The spring was contacting the brass screw ok but I noticed the silver tab on the coil did not touch the contact "button" on the dist. cap. I tried bending the tab a little but I broke one off in the past so I'm very cautious now.
I'll keep trying to align the tab to the dist cap button.
Bruce (VA)
12-06-2012 13:19:04
 Re: 1947 9N Starting issues in reply to jdlingerfelt, 12-06-2012 11:36:39
Ahhhhhhh yes, tip # 5 on my list of 'frontmount failure points':
5. The tab on the bottom of the coil not making contact w/ the brass button on the cap. (With the cap on, the tab must firmly contact the brass button. No contact = no spark.)
Chances are you found the problem.
jdlingerfelt
12-06-2012 14:42:04
 Re: 1947 9N Starting issues in reply to Bruce (VA), 12-06-2012 13:19:04
Bruce,
I"VE GOT SPARK !!!
Getting it to start should be a piece of cake compared to what I"ve been thru,
Again, many thanks for sticking with me.
Joe L.
Bruce (VA)
12-06-2012 15:05:07
 Re: 1947 9N Starting issues in reply to jdlingerfelt, 12-06-2012 14:42:04
You're welcome. Glad to help.
Just don't flood it.
While each N has it's own starting sequence, none of them will start well by just yanking out the choke rod & holding it out for 5 or 10 seconds while the engine cranks. This is an updraft carb w/ a gravity fuel system; it is by it's very nature subject to flooding. Too much choke makes it happen.
Try this:
Key on, gas on 2 full turns, clutch in, 3/4 throttle, press the starter button. Let it crank for at least 3 - 4 seconds before you pull the choke rod. Then, don't hold it out for more than 2 or 3 seconds.
