TractorLinks.com
Show Parts for Model:
Re: 2N engine evaluation: no sleeves!
TheOldHokie
12-01-2012 08:23:05
I wouldn't call $700 shoestring tight ;-) But given your description of your budget and intended use I'd start by freeing it up, slap a fresh set of rings in it, bolt it back together, change the fluids and take it out for a test run. If it will pull and spin the mower you need for your airstrip I'd call it good to go for the time being and move on.
If it lacks power or makes worrisome noises that you can reliably identify as piston related then pull the engine and resleeve it:
Sleeve and piston kit - $160.
Boring - 4@500 - $200.
Miscellaneous bits - $140.
That's $500. If that $700 budget isn't coming out of the grand kid's lunch money you might just skip the first phase, speed past GO, and deposit $500 in the tractor. All of that presumes the lower end is not in need of attention which you really won't know for sure until you get it started.
TOH
