Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: fuel problem
11-29-2012 14:30:00
i usually make my own too.. but for a guy needing a one time use .. e probably don't have a bending tool.. and i figured the board could use the business.. :)
11-29-2012 18:34:38
 Re: fuel problem in reply to soundguy, 11-29-2012 14:30:00
Bending tool??? I have never used one yet when working with brake line but yes some people can mess up a cannon ball in a swimming pool
11-30-2012 11:35:29
 Re: fuel problem in reply to old, 11-29-2012 18:34:38
i figure if he is not stopping to read the description.. then free bending may be totally out of the question.. :)
11-30-2012 11:51:19
 Re: fuel problem in reply to soundguy, 11-30-2012 11:35:29
Yep last time I bent a circular bend in one I used a carb cleaner can as the form and worked just fine
11-30-2012 12:28:30
 Re: fuel problem in reply to old, 11-30-2012 11:51:19
A power steering pump or alternator pulley makes a good shade tree bending tool .
To the original post , remove the drain plug (1/8" pipe thread ) and replace with a $3 drain cock . If a constant stream of fuel will not flow into a coffee can then you can check one part at a time until you eliminate the problem .
